New T1R BMAX
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I just got my T1R BMAX's and I have put them on, however with only 1/4" more drop available in the rear I'm curious. I still have 2" of fender gap in the rear, thats stock ride height...gay... the front I'm tucking tire like crazy and its getting iffy if I can even raise it up high enough not to look stupid with the rear being so high. Has anyone else installed these and have any clue what problem I may be having. Something cant be right here, all the instructions are in Japanese so if anyone can help me out I'd appreciate it.
I measured the springs, for the rear I had to compress them (pre-load) to get it down to 2", so they ended up at a total height of 6 & 7/8". I can go 1/4" more on the coilover threading which is definitely not going to get rid of that 2" of fender gap. For the front I have them basically resting on the upper perch, no pre-load. I'm pretty sure I can get the front up enough but I'm dumbfounded why the rear is sitting so high. Any help would be awesome, Ben is out of town until next week. I'll get a picture uploaded to show you guys what I'm talking about sometime tomorrow.
Did you fully adjust the bottom perch so you didn't need to preload the rear springs?
There is 2 adjustments, you shouldn't preload the rear at all, and then take your lowering adjustments via the lower perch. You are doing something wrong.
There is NO way to leave 0 preload and be able to lower the car enough in the rear, like I said I only have 1/4" more to lower the car then the bottom spring perch would be hitting the bottom lock ring for the height adjustment. Do you have the coilovers?
AJ has closed until tomorrow for winter break
If there is a problem Ben will take care of it. I'm just curious if anyone else has bought them and had different results. My buddy is coming down tomorrow to look at it, he had some 1st gen T1R's.
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
I do have them, but I have not put them on yet. Stupid question but did you possibly put the rears in the front and the fronts in the back? There is a definite difference in length. Let us know how it turns out.
You cannot install them incorrectly, the rears are way too short to fit on the front.
I actually called Ben today and he is sending me another set of top mounts that will lower the car another 1/2"-3/4". They are not meant to slam the car, well the front will slam but the back wont anyways. Ben always makes things right so if you have the same problem I suggest just call him, I have a feeling they were meant more for the track than the street, but kept the street slightly in mind if that makes any sense.
On full soft they actually were less jolting than the OEM suspension.
![lol.gif](https://www.s2ki.com/forums/images/smilies/lol.gif)
