NEW RADIATOR OVERHEATING
The temperature control switch is mounted onto the new radiator, down towards the bottom , on north American cars it is on the driver side of the rad, there is a factory plug that connects to the switch. Peak down there with a flashlight and see if there is a connector plugged into it.
If everything is okay with the switch, then try to see if the rad fans are working.
Thanks I will have a look.
Just noticed a massive amount of heat coming from the log manifold and heating everything up really quickly. I have just had the manifold
repaired and all the heat wrap taken off as it contributed to it initially cracking. Previously - with all the heat wrap on there was very little
heat under the hood. I noticed the manifold really toasting the side of the engine block.
Maybe this is the issue ?
Ant
Yep its plugged in
Since you're in the UK why not Zircotec the exhaust manifold?
Yep its plugged in
From what you are desribing the system most likely has air in it.
Under the Hood Foum
--Top of page blue stickies
----FAQ, DIY, Maintenance
------Engine Stuff
--------1st post
--------------Billman 250 Coolant Bleed Thread
Utah
Under the Hood Foum
------Engine Stuff
--------1st post
Utah
Originally Posted by Pokemon' timestamp='1426439319' post='23540789
[quote name='JFUSION' timestamp='1426429376' post='23540670']
Yep its plugged in
[/quote]
Got it. A big nasty coolant leak. Thanks a lot fellas you have been brilliant and I really appreciate your time and effort.
