New Owner - 2005 S2000, drove hard after 700 miles
Originally Posted by Mad Paradox,Dec 8 2004, 04:56 AM
Didn't they change the Rev-Limiter to 8K to prevent mechanical Over Revving?
So, why is the F20C/F22C so susceptible to mechanical over-revving? Thanks in advance.
ANY and ALL fully manual transmission cars can be "mechanically" over-revved".
I think you don't understand what a mechanical over-rev is. It's been explained so many times already, I'll let someone else do it.
Originally Posted by Mad Paradox,Dec 8 2004, 05:56 AM
Didn't they change the Rev-Limiter to 8K to prevent mechanical Over Revving? Cause the older models Redlined at 9K. I don't know if this is related or not but I've been driving my EK with a B20 VTEC with stock internals and sometimes I'll shift it at 8,500-9K to purposely see if it will blow or do something. Its been a year and a half and still no problems. So, why is the F20C/F22C so susceptible to mechanical over-revving? Thanks in advance.
The ECU will prevent you from overrevving "up" into a higher RPM ... So if you're gunning it in first gear and you forget to upshift into second you can't rev beyond 8200rpms in the MY2004-2005s.
Mechanical overrevving is different. Its when you force the engine to rev faster than the redline by downshifting into a gear that makes the engine speed higher than redline. For example, you're racing and redlining each gear and redlining 3rd gear and you goto upshift into 4th but you mis-shift and accidently shift into 2nd. If you let up on the clutch your engine will now be forced to rev at an ungodly high rpm which it cannot handle ... The end result if you don't catch it in time is generally engine damage.
BTW- This type of overrevving can happen in any car (with a manual tranny, since the ECU controls shifts in most automatic trannies, it usually won't allow downshifts that would cause an overrev situation)... its not specific to the F20C/F22C. I guess in other cars without a rev limiter you can do an overrev by just running beyond redline though.
Not exactly a technical explanation there .. since my technical skills are limited, but hopefully it makes sense.
