New noise after TCT install
Old 08-20-2014, 08:17 AM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
Leave the camwheel bolt alone, post a sound clip if u like.
Old 08-20-2014, 08:45 AM
superchargedk20's Avatar
A howling? Do u have an aftermarket intake? They make a "howling" humming sound at idle
Old 08-20-2014, 09:58 AM
bgoetz's Avatar
I do, but it isn't that, this noise is directly from the front of the VC.
Old 08-19-2021, 11:59 AM
hapwn2220's Avatar
Default tct
Originally Posted by Billman250
This is a very far out comment and I assure you 100% it is not the case.
The chances of you camwheel bolt being loose is under 1%.
i just installed mine the moment i got back from a underway, annnnnnnd the rattle is still there. sometimes it would go away when i’m at idle but most of the time the rattle is there. what do i do ? i followed the steps carefully all but one, i don’t have a tool that can measure pounds. is that the case on why it’s rattling still or do i need a readjustment on my chain itself
Old 08-19-2021, 03:35 PM
Chuck S's Avatar
Received 1,231 Likes on 1,075 Posts
2006 and later engines commonly have tight valve clearances -- which are quieter than loose clearances that clatter -- so my guess at this distance is it ain't the valves unless they're hypertight. The data when you measure the clearances will be valuable.
-- Chuck
Old 08-19-2021, 04:14 PM
Billman250's Avatar
Bolt torque has nothing to do with your noise.
Post a sound clip of the noise. 4 feet away from the front of the car, hood closed. Let’s see if it’s chain noise, or something else.
Old 08-20-2021, 02:59 PM
hapwn2220's Avatar
Default tct
i just took it to the shop and they’re telling me the rattle is from the catalytic converter... are they right ???? help
Old 08-20-2021, 03:57 PM
Billman250's Avatar
Wow that’s pretty far off from TCT noise.
Yes, cat rattle very common problem.
Old 08-20-2021, 05:00 PM
hapwn2220's Avatar
Default tct
i thought it was the chain and that i had to get a new one. so are they right ?
Old 08-21-2021, 02:26 AM
Billman250's Avatar
Bang on the cat flange with a rubber mallet, see if it rattles. I’ve seen it many times.
Slowcrash_101 (08-21-2021)
morphenyou
09-29-2018 10:33 PM
R3AL-STATUS
03-16-2014 03:25 PM
Tboy
03-01-2014 01:01 PM
dtmcnamara
09-09-2009 02:59 AM
05TurboS2k
41
03-27-2008 04:35 PM
Quick Reply: New noise after TCT install
