New Motorcraft 10w30...outstanding minoil
Hey gang,
For how to get this info and anything else you ever wanted to know about oils, check out the forums at www.bobistheoilguy.com
Later
Drew
Later
Drew
Originally Posted by oakfloor,Nov 21 2004, 11:40 PM
yeah I also run amsoil 10w-30, but Im scared to leave it in that long. I have tried in the past to leave oil in for as long as the factory recommends.. and I just cant do it. I hate to see black paint draining out of a car or truck I paid so much for. my s2k's oil will get dark at about 2k, and at 3k it comes out.
Originally Posted by jyeung528,Nov 22 2004, 02:38 PM
Road Rage, is this Motorcraft non-synthetic?
If it is, wouldn't it be better to stick with Amsoil since Amsoil is synthetic?
To be fair, the Motorcraft is not a true synthetic, but rather a hydrocracked dino oil. Some manufacturers are labeling these as synthetics, even though they have a conventional base.
If you are using Amsoil, by all means keep using it. It is one of the best synthetic motor oils on the market... this Motorcraft stuff is just another alternative for those deciding between Castrol GTX, Valvoline, Honda (Mobil DriveClean), etc... but since you are using a synthetic, no reason for you to digress in lubrication technology.
Amsoil is one of those extended life type of oils where you can go longer between oil change intervals. You can go at least twice as long between oil changes... don't change simply because it is black...
thanks for all the info, yes Im a waster of good oil. Im gonna leave it in longer this time and replace the oil filter at about half way thru. but I do recycle it. So where can I get a UOA done?
guys
I have looked for this stuff at three Wal-marts and i don't think they carry this oil anymore - I also called a local ford dealership and the guy was clueless
I ended up picking up some penzoil for this change BUT where do you find the motorcraft stuff
Thanks
steve
Thanks
steve
