New metal taping sound ahhh!
Hear is the you tube link to both of them let me know if they work I don't know what the problem is ...
http://m.youtube.com/?tsp=1#/results?q=weldabike
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Also Valves don't bend from low oil. False information.
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
There is NO WAY low oil will bend valves!
If you run the engine without oil, the valves could likely go a few MILES down the road before they would stick.
That doesnt matter, because the engine would lock up in the first 10 feet.
Compression test in c1 was 185 c2 was 181 c3 was 176 c4 was 158 does that sound bad ??? Don't know what to look for in this motor.....I was thinking 150 to 180 might be good ? Or not so good ... Cutting the oil filter tonight hopefully.
Thanks for all the good tips hope it is not a rod! Or it looks like I am going to be rebuilding a motor!
