New Key
Originally Posted by jeggy,Jun 18 2009, 05:35 PM
or you can tape you one key to the steering collum to register the immobilizer and use as many copied keys you wish. yay!
Tape the original key inside the steering column cover, by ignition lock. Prior to that, make 2 copies of that key. with the original key's chip signal by the ignition, immobilizer will think you're using an original key whenever you're starting the car with a copy. viola!
But you'll loose the immobilizer as a security device.
