New Clutch?
Get the clutch piecemeal if you have to, as long as you ONLY buy genuine Honda parts. The most expensive thing is the pressure plate, resurfacing the flywheel should be possible with your mileage.
You can use hondapartsnow.com hondaautomotiveparts.com hondapartsnetwork.com those have the best prices for everything. All in, you're looking at around $580-750 in parts(the flywheel is pretty expensive brand new) plus around $450-600 for labor, or if you're a bit of a masochist, you can spend $350 in decent tools and do it all yourself. Assuming you have no jack, jack stands, wrenches and sockets, extensions, universal joints, a tq wrench that can read up to 150ft lbs, a pry bar, a hammer, Honda ultra high temp urea grease, allen sockets, and a vice grip. If you have most of these things then obviously your tools cost will be lower.
If you take it to Honda or a regular shop there's no guarantee they won't eff up the knock sensor, as it's so easy to bust up.
Plus the good thing about having tools is, that you can use them again to fix other stuff on the car, or use them to do maintenance on it.
Any harm in me ordering the part and having them doing the install? Also, should I forgo ordering a new flywheel since mine might only need resurfaced?
Thanks again.
I did find a highly rated shop that will do the clutch swap. Their quote was $1,600. They also said they would replace the clutch if I brought in the part, instead of them ordering it. (their cost for the clutch was $1000.)
Thanks again.
Thanks again.
$1,600 just for labor is a lot, I charge ~$1,300 out the door(sometimes a little more depending on the parts they want), that's labor plus parts, and that's with me replacing the rear main seal, the flywheel, and the release bearing guide sleeve, and using all OEM parts. A lot of shops, if you give them parts to install, they won't give you any warranty, so if something happens you'll be on the hook for labor again, present company included. Not that they won't do it, it's just a lot of shops make a bit of extra money off parts, because getting the parts and all that is a service onto itself.
Received 1,418 Likes
Good lord. $1600. Solid gold wrenches.
Very good shops in this area (chicago burbs) charge between $300-500.
Thanks again.
Thanks again.
Parts: $1000
Labor: $600
That being said, you think I'd be good to not order a new flywheel?
Little niggles like this are the reason the only person that wrenches on my car is me. Too many unscrupulous shops out there that will cut corners to make a buck.
Originally Posted by jdl06osu' timestamp='1442508069' post='23749866
[quote name='Slowcrash_101' timestamp='1442343379' post='23747747']
[/quote]
I agree with ya. I wish I had the mechanical know-how and tools to do it myself. I wont have the clutch installed without at least resurfacing the flywheel.
I would see if you can find a AP1 flywheel, its lighter(but not to light) and makes the car funner to drive. You can find them for not much money. I mean you got it all apart, so why not add a lighter flywheel? I plan to do this with my '06 when my clutch goes bad(have 117k miles on it) but not until then.
ROD
ROD
ROD
ROD
