New to AP2 seems like revs are hanging...
I do't remember the 2001 model I had a couple of years ago doing this but with the 04 I just bought the revs are hanging when shifting, did my 01 do it and I just don't remember or is this a characteristic of the AP2?
Will getting an ECU flash or upgrade from Hondata take care of it?
But if I remove the cdv its only a short matter of time before the clutch pressure plate needs to be replaced from what I've been reading, I'm not interested in doing that so I guess I'll get used to the revs hanging a split second when I hit the clutch.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Nah...I don't think it is all that hard on the clutch pressure plate. I know a ton of guys running without the CDV...one is approaching 100k miles on his ap2 and autoxes the crap out of his car.
1 Post
Originally Posted by S2Kage,Feb 27 2009, 02:00 PM
CDV = clutch delay valve
the revs hanging are due to heavy flywheel... revs slipping is CDV or bad clutch lol
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
And if you pull the CDV you should not be in AS.
