New ACT Clutch - Break-in Advice?
Hello all...
My stock clutch setup is dead and I'll be having an ACT HD clutch/pp setup installed on Tuesday... I'm excited, to say the least.
Does anyone have any good advice for breaking that bad boy in? Is there a certain amount of miles I should put on the clutch before REALLY playing with it? Any other operational advice would be appreciated!
Don't forget that actual clutch engages count more than miles. I beleive its recommended that you engage the clutch at light shifts around 700 times. It may sound like a lot, but really isn't.
cool! i can deal with that... and let me say, i'm excited to be done with the OEM **EDIT** Clutch and on to something that's (hopefully) built a little better.
Yeah really you can get on it as hard as you want as long as you ingage the clutch properly (making sure the clutch is fully ingaged before getting on it)! Just be easy between shifts... having the same clutch myself you should really like the ACT. ~nate
Originally posted by jono
cool! i can deal with that... and let me say, i'm excited to be done with the OEM transmission and on to something that's (hopefully) built a little better.
Clutchmasters recommends an 800 mile breakin period (I think, but it's been a year since I had the Stage III installed). In any case, just be gentle until you log some miles.
CB
_________________
C. Bender
2001 Silver/Black
Turbonetics TO4B 60:1 Ball Bearing Turbo; Tial 46mm Wastegate and 50mm Blowoff Valve; GReddy EGT and Boost Warning Gauges; Speedcraft Front Mounted Intercooler, Mandrel Bent Tubing, 3 Inch Down Pipe, and 3" Stainless Exhaust; A'PEXi N1 Mufflers; AEM EMS, Fuel Pressure Regulator, and Wideband O2 Sensor; RC Engineering 550 Injectors; Holly 250 Forced Induction Fuel Pump; Oil Filter Relocation Kit with Stainless Steel Lines; Clutchmaster Stage 3 Clutch; Toda Lightweight Flywheel; Mugen Radiator Cap, Thermostat, and Fan Switch; Upgraded Oil Bolts; Hecash Brake Ducting; Competch Stainless Steel Brake Lines; WorkMeister S2R 18" Wheels; Spoon X-Brace; Muz Shift Knob; Lucid's Front and Rear Speakers; 2002 Stereo Head Unit; Rick's Front Badge; JDM Clear Side Markers; Uber Cool Nurburgring Decal
CB
_________________
C. Bender
2001 Silver/Black
