Neo, GM syncromesh, Redline...
All these have been discussed at length - see some of my post or search on topic. I do not consider NEO fit for our cars, as its specs are absurdly low in viscosity.
It really depends so heavily on your usage and the typical ambient temperatures...
Stock Honda fluid works great for a little while, but seems to fall apart when it is older, especially on really hot days at the track.
Red line MTL is a little thin, Red Line MT-90 is a little thick. If you are doing a bunch of track work and the climate is hot, I think MT-90 is a good solution. Mixing MT-90 and MTL 50/50 is an option for street use and occasional track, but the shifting will be stiff when cold.
No experience with Neo...
As mentioned above, a search will give you lots more opinions, some of the threads might also be in racing & competition, can't recall.
GM syncromesh didn't do anything for me, and I likely wouldn't opt to use it again.
I find Honda MTF to be perfectly acceptable here in VA where the temp varies quite a bit year round (90+ in summer, sub freezing in winter). It's a little notchy in the cold (but if you can show me a manual that isn't when it's 20F out, I'd be surprised), and once it warms up it's great.
I think the important thing is that some trannys like some fluids more than others. For my tranny, Honda MTF was shit. Of the 5 fluids I tried, it was the worst by far on the street or track. The only way I could go a single day without grinding into a gear was to not drive. Urine might have worked better.
