Need some quick advise on coilover install
Old 08-12-2004, 05:39 PM
Diez's Avatar
Default Need some quick advise on coilover install
Hi all,
I'm trying to put together my coilovers and wanted to know if there is a specific tool I need to tighten the top mount onto the shock shaft. See picture.
Tightening the top nut is no problem, but you need to hold the shaft with something. On the stock shocks its an allen head. With these, do I just use an open end wrench (8mm was too big so it looks like it might be 6mm) or is there a specific tool for this? Thanks for the help
Marco
Old 08-12-2004, 10:26 PM
yogi's Avatar
Pliers don't work?
Old 08-13-2004, 06:00 AM
Diez's Avatar
Originally Posted by yogi,Aug 13 2004, 02:26 AM
Pliers don't work?
I tried using lock pliers, but you have to torque the bolt down so much that the pliers start stripping the top.
Old 08-13-2004, 09:58 AM
SOHCmyDOHC's Avatar
Yes there is a special tool for that. I believe you can get it at your local parts store. Or you can do what I did. Take a deep socket and an impact gun and shoot the nut until the top hat twists too!!
Old 08-13-2004, 03:31 PM
Diez's Avatar
Hey thanks SOHCmyDOHC,
I went to Napa, Pep Boys, Harbor Freight, and Northern Tool, and found one cheap universal kit, but it won't fit the slot because its too small. I have an impact wrench and deep socket but I'm concerned about just impact-wrenching that bolt down. Won't the shaft just spin with the bolt (like its doing now when I try torquing it to 22 ftlbs)?
Thanks for your help,
Marco
Kaneda215
07-17-2011 09:54 PM
s2kZac
11-05-2009 10:23 PM
MyEeek
05-27-2008 02:30 PM
808style
05-13-2005 12:07 AM
smccurry
05-07-2005 01:43 PM
Quick Reply: Need some quick advise on coilover install
