Need Some Assistance
What does the code P0303-0302 mean? I took it to the Honda dealer and they replaced my spark plugs and did a valve adjustment. They also replaced the serpentine drive belt, swapped the coil packs, swapped fuel injectors, and did a compression test all which came out good. They said its either a valve issue or something on the lower end of the engine, at a warm idle I hear a very light knocking. What do you guys think I should do?
Those codes mean you have a misfire in cylinders 2 and 3. It sounds like your dealership did a lot of guesswork at your expense. Misfires are usually an issue with spark, fuel or compression. Did they try a leak down test? Did they wait until the engine was cold before adjusting the valves? You could possibly have some bent valves... have you ever mis-shifted and over-revved the engine?
A hot valve adjustment (in my experience) would not be enough to cause misfiring, more likely to cause poor economy, reduced power and excessive ticking noise.
I hope you didn't pay for any of the repairs (especially the serpentine belt?). The dealer can easily swap coil packs, injectors temporarily to diagnose but should return yours after confirming no change.
Do you have the spark plugs that were pulled? Honda VTEC engine spark plugs read like book when it comes to running conditions inside the cyls. Any more information?
So I'm not sure if they did a leak down test, it just says "compression test: good" on the work order. also dont think they waited for a cold engine to do the valve adjustment. Worst case scenario what would it cost to replace whatever may be bent? I know I sound stupid because i'm not mechanically inclined, will driving the car hurt anything worse than it is? The total for that visit was $696. The car is approaching 160k this was diagnosed at 156k
I havent owned this one for that long, I have 2. One garage queen NFR and then this Berlina 02. The previous owner did admit he didn't buy an s2000 to drive it slow lol,he was the original owner. I would guess he may have had a few miss shifts in 10 years. Appreciate the help guys keep the good info coming!
Originally Posted by NFRAP2' timestamp='1334470967' post='21608776
[quote name='zhashmi' timestamp='1334463992' post='21608639']
[/quote]
It's hard to say if and at what rate the problem will be accelerated without knowing exactly what the problem is, but I would not drive the car as long as there is a misfire if you can help it as unburned fuel passing through the exhaust can damage the catalytic converter and your oil can become diluted with fuel. Based on the fact that you say it drives fine at speed but has issues at idle, it really sounds like a compression issue. I have witnessed a car that exhibited the same symptoms before and it turned out to be low compression in cylinders 2 and 3 due to a crack in the headgasket between these cylinders. I would advise either doing another compression check yourself (very easy task, if you can change oil you can probably handle a compression check) or have another shop that you trust do a compression check. If you had a bad coil or fuel injector, you would most likely have noticeable stumbling/misfiring at speed. I know that they said the compression was "good" but I wouldn't trust whatever work they did at this point because it all sounds really fishy. Did you have the exact same P302/303 codes both before and after the work was performed?
