Need to replace front studs
Hi all,
I crossthreaded a lug and would like to replace all my front studs. I know the bearing has to be replaced, but will the hub need to be replaced? that's another $200 for the hubs if so.
From reading, people are saying the hubs can be damaged from bad bearings, but if my bearings are fine, I should be able to reuse my hubs and just replace the studs, correct?
Thank you!
Thank you!
