need to pull ABS code
Can you unplug each sensor at the clip and test them for continuity?
I had one go bad and couldn't figure out which one it was. The shop I brought the car to tested all 4 sensors with a voltage tester and somehow figured out which one it was.
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by hondaf1,Nov 15 2010, 07:07 PM
is there only one SCS connector? the yellow plug on under the dash on the driver side connected to the fuse box?
Originally Posted by Billman250,Nov 16 2010, 04:55 AM
That connector is for airbag codes, not ABS.
Originally Posted by hondaf1,Nov 16 2010, 07:35 AM
oh, ok. is there a similar plug for the ABS codes, like the one in the youtube video?
You use the ODBII port. Short pin 9 and 4 of the ODBII port.
crits2k
06-11-2008 09:20 AM
