need to pull ABS code
Old 11-15-2010, 10:01 AM
hondaf1's Avatar
Default need to pull ABS code
i was removing the coilovers and i think i stretched one of the ABS sensor cable. i think i know which one it is but i want to pull the code and make sure before i buy the sensor. is there a way to pull the code without going to the dealer.
Old 11-15-2010, 10:09 AM
Stratocaster's Avatar
You can pull them with the old short the pins in the ODBII port method. The helms manual covers it as well.
Old 11-15-2010, 10:15 AM
The Gent's Avatar
buy a odb2 reader and bring it back when you're done. lol
Old 11-15-2010, 11:15 AM
Yeah, that does not work. The ABS codes can not be read using an ODBII reader.
Old 11-15-2010, 01:26 PM
hondaf1's Avatar
thanks, i'll check the helms manual.
Old 11-15-2010, 02:30 PM
hondaf1's Avatar
this is the instruction i used from the manual but i used a piece of wire instead of the PGM tester. the ABS stays on and does NOT blink, so i can't get the ABS code.
Service Check Signal (SCSI Circuit Method)
1. With the ignition switch OFF, connect the Honda PGM Tester (A) to the 16P data link connector (DLC) lB) undert he passenger's side in the dashboard.
2. Short the SCS circuit to body ground using the Honda PGM Tester.
3. Turn the ignition switch ON (ll) without the brake pedal pressed.
NOTE: lf the brake pedal is pressed when turning the ignition switch ON { ll), the system shifts to the DTC clea ring mode.
4. The blinking frequency indicates the DTC. DTCs are indicated by a series of long and short blinks. One long blink equals1 0 short blinks. Add the long and short blinks together to determine the DTC. After determining the DTC, refer to the DTC
TroubleshootingIn dex.
NOTE:
. lf the DTCi s not memorized,t he ABS indicator
will go off for 3.6 seconds, and then come back
on.
. lf the ABS indicator stays on, troubleshoot for
"ABS indicator does not go off" (see step 1 on
page 19-57).
The svstem will not indicate the DTC unless these
conditions are met:
. The brake oedal is not pressed,
. Thei gni t ions wi tchi st urnedO N { l l ) ,
. The SCS circuit is shorted to body ground before
the igni t ions wi tchi st urnedO N ( l l ) .
Old 11-15-2010, 02:37 PM
So if you just start the car and drive is a block or two, will the ABS light still be lit?
Old 11-15-2010, 03:07 PM
hondaf1's Avatar
the ABS light comes on when the ignition is turned ON, then stays on the whole time, even after driving for many miles.
is there only one SCS connector? the yellow plug on under the dash on the driver side connected to the fuse box?
i found this video on youtube but it's for a prelude. the SCS connector on the s2k is in a different location.
[media]http://www.youtube.com/watch?v=2udokGbrHGI [/media]
Old 11-15-2010, 03:25 PM
The SC connector is the ODBII port. Pins 4 and 9 shorted. The same as you would use to be the flash code for a check engine light. In fact you can get the EPS codes from here too.
Old 11-15-2010, 03:54 PM
hondaf1's Avatar
how do i pull codes using the obd2 port. jumping the plug next to the fuse box is not working.
also, i just did a continuity test on all the sensors and the passenger rear had an open circuit. it's also the one that i knew for sure i stretch while removing the control arm.
Quick Reply: need to pull ABS code
