need to know who makes the sitffest shocks
Old 08-02-2004, 10:10 AM
mustangkiller01's Avatar
my tires are nitto555 extreams if that helps... they seem wider than normal..
Old 08-02-2004, 11:56 AM
aklucsarits's Avatar
Different dampers will not help your situation.
You can try a couple of things (some suggested already):
1)Use firmer springrates, so that they do not compress as far.
2)Use the same spring rate, but raise your ride height up a bit.
3)Use wheels/tires that fit your car's suspension setup.
4)Use an agressive alignment with more negative camber so that the tops of the tires tuck into the fenderwell better.
Andrew
Old 08-02-2004, 12:34 PM
i think i will have the fenders rolled and try a aggressive alignment... it is a little negative right now due to the spring drop but a little more and i don't think they will rub.. this will decrease my contact patch and cause faster wear on the tires though i think
amos
06-23-2008 09:28 PM
samura1
08-24-2005 08:04 AM
reds_s2k
01-17-2005 02:58 AM
mustangkiller01
07-31-2004 08:53 AM
BlueS2000Boy
04-02-2003 05:24 PM
Quick Reply: need to know who makes the sitffest shocks
