Need Honda Bearing Thicknesses for F20C/K24A2 Stroker Build
My shop is in the middle of building a F20C stroker using the TSX crankshaft. I am currently stuck while trying to figure out the Honda F20C main and K24A2 rod bearing sizes. I have the line bore of the block, Big-end bore of the rods, and journals of K24A2 crank all measured out so all I need is a chart of the bearing thicknesses as they relate to the colors they are named. The block is DDDDD, crank is 45544 on main and BBBB on rod but with the aftermarket rods I have no ID #'s or letters. I would rather know the exact measurements of the bearings anyway so I can get the exact tolerances I want. If anyone can help me out thanks! If not I guess I'll buy all of the bearings and figure it out.
