Need help whats this sound
Old 04-16-2010, 07:31 PM
PitchBlackAP1's Avatar
Default Need help whats this sound
I think its the wheel bearing but i may be wrong
video link here-->[media]http://www.youtube.com/watch?v=_8KadSKlFyc [/media]
Old 04-16-2010, 08:41 PM
Bump
Old 04-17-2010, 07:22 AM
SpitfireS's Avatar
It sounds like something is about to go boom!
Its not as simple as the brakes.. is it?
Old 04-17-2010, 09:12 AM
nah it only comes from the right rear wheel
Old 04-17-2010, 09:14 AM
any ideas?
Old 04-17-2010, 12:42 PM
jyeung528's Avatar
well, i would start a brake inspection and then change the wheel bearing/hub.
Old 04-17-2010, 12:43 PM
jyeung528's Avatar
assuming you already inspected the tired for warpage
Old 04-17-2010, 01:08 PM
nah cant be the tire because the day it started i was running old tires then went to a new set and it still making that noise, also i wasnt hiting the brakes when that noise happens even when the brakes r added it still makes the noise btw it only does it when u slow down/let off the gas
Old 04-17-2010, 01:33 PM
1nate7's Avatar
It seems like you have the symptoms of a bad wheel bearing. Another clue is if you hear it when making slow turns like in a parking lot, but only when you turn the direction that loads up the bad bearing (left turns in this case). It's hard to tell from the video, my bad bearing made a metallic scratching/scraping sound.
Agree with the brake inspection though, it's quick and although unlikely, you might find a rock stuck in the caliper or something. You can also try tightening the axle nut, it's not a permanent fix but if the noise goes away you know it's the hub/bearing.
Old 04-17-2010, 04:38 PM
ok ty alot ill try that asap
Quick Reply: Need help whats this sound
