Need Help With A Sway Bar
I was talking about the front sway bar. The coils had been installed already. In the adjustment holes, I can only put the bolt in the farthest or softest hole. Otherwise it touched the coilover.
remove bar and send it back for modifications.
that seems to be your only option here. if there is an external canister on your coilovers, make note of that. take lots of pictures, and put up a ruler or some other measuring device so you can show it to saner and I'm quite sure they will correct it.
I haven't heard of this bar. Could someone direct me to some info? I thought Comptech had the only adjustable bar.
On another note (sorry), does anyone make adjustable end links for the S?
gernby - check out the racing & competition forum for info on this bar.
as for adjustable links - you can put together yourself a kit, or I can create one quite easily to sell if you'd like. =)
