Need help removing valve cover
I'm all out of ideas....anyone know a good way to remove a stripped valve cover bolt? I have a dremel, but not sure if I should drill a hole.
![](http://i46.tinypic.com/31770bl.jpg)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
umm if you can't get at it easily perhaps a chisel and knock a groove in it?? so you can get a screwdriver in there perhaps?? then at worse drill the head but you would have to retap the hole etc so a PITA.
Make sure block completely cold too
These screws are actually soft. Easy to drill. Try a screw extractor and 1/8 or 1/16 drill bit. I believe these are M6 so close to 1/4 Standard. The extractor...
http://www.grainger.com/Grainger/items/1U216
If you're able to do it this way you don't have to worry about damaging anything.
A nice set of easy outs. They are like reverse drill bits that drill into a little and pull it right out. Love mine.
Although that is tight clearance the post above me might be more up your ally. I would recommend one or the other though.
http://www.sears.com/shc/s/p_10153_12605_00952168000P
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I vote for cutting a slot with a dremel then using a flat bladed screwdriver to remove it. I've used that method in the past.
If that doesn't work you could still use the easy outs.
