Need help removing center console trim!~
I went to the local dealer and they don't have the service manual in stock....was going to order one but would like to get started removing my interior so if anyone can help me out by scanning a few pages of their manual, I will be eternally grateful!
Need to find out what steps to take to remove the center console door, and upper cover center console pieces for painting. Then it's the roll hoops that have to come out.
If anyone who has experience taking this stuff out and can chime it that would be appreciated too!
thanks,
rick
thanks,
rick
radio door:
put shifter into reverse and lower radio door.
pull on radio door laterally (towards the back of the car and straight), and the bottom clips pop out.
Now use a flat head screwdriver (covered in tape so as not to scratch) and pry off the clips at the top around the vent areas.
its all one piece and will come off together.
center console:
remove shift knob
start at the rear of the console and pull up sharply to pop off the clips.
work your way forward exerting even pressure all the way along
it will eventually come free.
neither of these are hard to do - should take you no more than 5 minutes for both pieces.
center console:
remove shift knob
