Need help please other wise I am really gonna sell the s
#23
Originally Posted by S2kruss87' timestamp='1387831712' post='22935817
Oh dam that ain't good then. Is it normal when you put it in gear you can feel a clunk under the seats??
Sent from my iPhone using Tapatalk
Okay cool thanks. We'll I think I have found what the noise is. inner pinion bearing maybe because I have whining when I pull away too.
From what I read here, your issue is a bad differential/third member. The fix is simple, replace the rear with a good used unit or a quality rebuild.
If you have any trouble finding a good diff in the UK send me a PM, I ship to the UK
#24
Drive the car. Do everything you can to make the noise happen.
Try to find which action makes it occur.
What is this specific action?( turning right while accelerating? Braking. While starting from
A stop or changing gears, etc. )
Is there more than one noise?
Where do you hear it coming from?(turn your radio off) (rear left, rear right, rear center, mid center, etc)
Try listening with the top up and down.
Is it a continuous noise? Or is it intermittent?
Inspect the underside, is there any obvious signs of repair from an accident or other serious damage?
Try to answer each question so we can assist you better.
And this was sent from my phone using Ag app.
#25
#26
Her's actually sounds like a sticking caliper piston from what I can tell.
#27
Originally Posted by S2kruss87' timestamp='1388737575' post='22947823
Right. It happens when I'm coming to a stop. Does it about 5 out of 10 times I brake don't have to be going fast,it happens as I'm coming to a dead stop 99% it's the right rear. You can hear it in the car and out side of the car.
#28
The piston on the rear calipers has to be screwed inward to retract them for service. FYI. If you can't do that. Bad caliper.
Also check your end link for the swaybar and the sliding pins/bracket for the caliper
