Need help with parts behind passenger rear wheel
Start here and look up the diagrams. I'd be mostly concerned about the subframe whether it was bent on impact; hopefully it only shifted left. G'luck
https://www.hondaautomotiveparts.com...artsSearch.jsp
Control arms, The rod is responsible for camber, the upper control arms, and lower control arm, the shock mounts to the lower control arm, you also busted the knuckle, that car will never be aligned again unless you fix all that, and that's if you have no frame damage.
Replace those broken parts and inspect the rear subframe for any damage that's visible. Get it aligned and you should be fine if it won't align properly most likely your rear subframe is damaged. There not expensive and easy to replace.
no frame damage luckily
only part im missing is this little thing
http://imgur.com/a/vSsbc
anyone know what thats called?
nvm got it
Sway Bar Rear passenger STABILIZER LINK
nvm got it
