Need Help, oil light flashed
Old 02-28-2016, 07:38 AM
windhund116's Avatar
Received 1,526 Likes on 1,030 Posts
Originally Posted by zeroptzero
The real name of the light is the engine death light.
I call it an "idiot light." Because that's how I feel when the thing lights up.
Old 02-28-2016, 09:03 AM
freq's Avatar
Originally Posted by pdpsihavok
however when i went to ccheck the oil level after it sat overnight, i couldnt see the oil at all lol but when i started it, it was fine...
Wait, you let the car sit overnight, checked the oil, couldn't see it at all on the dipstick but yet still started it?
Is that correct?
Old 02-28-2016, 09:21 AM
pdpsihavok's Avatar
well its a tiny tiny bit of oil... haha
Old 02-28-2016, 09:32 AM
Backmarker's Avatar
I feel like this should be obvious... but just in case:
When it came on, you should have checked the dipstick before adding oil.
Once you added oil, and still didn't get a reading on the stick, add more before starting it or doing anything. The stick goes into the sump, its not like the oil is being secretly hidden somewhere in a top secret attempt to get you to over fill it. If there is nothing on the dip stick... add more.
You shouldn't have been able to burn an entire serving of oil in a regular time period, so either you have a leak somewhere, or you haven't changed that oil in ages...
So change your oil, and filter with new oil. (All the way to the dipstick reading this time) run it in a stationary place for a while and check for leaks. If there are no leaks, drive it for a week, and check the dipstick again.
If its lower than before, you have a leak. If its not -- hope you didnt do any damage and move on. Just keep checking the dipstick.
2000ths
01-18-2013 04:45 PM
s2000maniac
09-07-2012 07:47 PM
climhazzard
07-05-2012 09:09 AM
J.W.
03-02-2010 11:43 AM
HankookS2K
09-18-2008 07:07 AM
Quick Reply: Need Help, oil light flashed
