Need help! Left rear wheel area noise!
Old 03-08-2006, 08:10 PM
  #21
Billman250's Avatar
Received 1,397 Likes on 837 Posts
Anytime.
Note Modifry's friends bearings, at stage 4
Old 03-09-2006, 06:27 AM
  #22
Clayman's Avatar
What size is the axle nut?
Old 03-09-2006, 06:41 AM
  #23
kent-k's Avatar
is this for all years? i have an 02 and an 05. also what about the front nut? is it a taper bearing?
sorry for all the ?'s
Old 03-09-2006, 02:01 PM
  #24
Billman250's Avatar
Not a taper bearing. Inner races hold it to a preset load.
Front won't be a problem.
I've done this on 04's, not sure when or if it was ever rectified.
Axle nut is 36mm or 1 7/16".
Old 03-09-2006, 03:22 PM
  #25
kent-k's Avatar
thanks, your info is always appreciated
Old 03-10-2006, 12:40 PM
  #26
dbzerk's Avatar
Originally Posted by Elistan,Mar 8 2006, 01:03 AM
Can your torque wrench do 220 lb-ft?
Just found out mine only does upto 150!
I'll try to borrow one from somewhere.. thanks for the great info again. Let you know how i go!
Old 03-13-2006, 11:38 PM
  #27
dbzerk's Avatar
Pressed the hub out of the bearing..
This is how it looked:
Need a new one huh?
Old 03-14-2006, 06:44 AM
  #28
mic_crispy's Avatar
okay well i did this the other day.. odd results. i torqued the nut to spec (220) and it was in the same position that it was before! maybe it went all the way around an extra time? i doubt it... anyway my car is lowered pretty good. esp in the rear. so i raised up my drivers side rear a bit, so that when i get into my car, its even with the other side... and i put alittle more preload in the rear(both tires)...so i dont know what fixed it, but its gone now! just thought id let yall know...
Old 03-14-2006, 12:37 PM
  #29
dbzerk's Avatar
Is this what a worn out hub looks like??
Old 03-14-2006, 01:51 PM
  #30
ThatllHappen's Avatar
You are the man billman!! I have been hearing the slight clicking in reverse from time to time (just started making the noise) and was wondering what it was. Was meaning to search to see if I could find something. Will have to tighten it a.s.a.p.
Quick Reply: Need help! Left rear wheel area noise!
