Need help identifying parts for replacement
Hi,
I've noticed a coolant (?) leak from two pipes behind the engine and I cannot figure out what Part Number they have.
I contacted two shops for used replacements, but I'd like to check more sites to see if I'm able to get new OEM parts instead;
I'd need both the metal pipe and the tube, at least that's what my mechanic told me. It seems the tube is all rotten. (I had to replace other coolant tubes already last summer, so it's probably about time that they got replaced.)
Any help is appreciated!
Thanks!
Thanks!
The pipes are 79724-S2A-A02 and 79727-S2A-A02
If you click on the links you should see any hoses that might be needed as well.
Kutwazluz (04-07-2021)
