Need help.....how to reset ECU
Old 07-27-2001, 05:46 PM
stookfreak's Avatar
RT- Just got that from s2000 news. That was the first thing that I said when I read it. Then later it was more like duh!!!
I am talking only about resetting the light which will go off at times if you do not take the stook to the shop for service. If I am not mistake this will light up at intervals to remind you for the service. If you do your own you will want to reset.
You're right the back flow may be causing the lack of throttle response- but I don't know how to fix- just know that my friend had similar problems when he installed a new exhaust on his civic. I'll try to get in touch with him to see what he did to fix.
Whether or not this would bring the light on is another question which I do not know.
Maybe some more expertise out there on a/m exhausts that could help you.
Old 07-28-2001, 03:20 PM
S2000spoon's Avatar
stookfreak,...
sorry for the misunderstanding....
thanks for the info...it was very helpful....
the funniest thing happened.....the lack of throttle response has
dissappered...gone....vanish....car is running fine again....
i believe that the computer fixed itself...i've heard the ECU
will adjust to changes....is this true..??
anyone??
Old 07-28-2001, 04:41 PM
Takashi KazuMori's Avatar
Yes, Honda ECUs have a bit of "Learn" ability ... Gets awhile to be used to new settings but if they're not too drastic changes that will affect the ECU stock mapping then it shouldn't be a problem.
Old 07-28-2001, 05:31 PM
Schatten's Avatar
this information is also documented in the FAQ section of this site.
AW01
12-22-2011 12:29 PM
dojo19xx
10-21-2011 06:54 PM
07RioS2k
10-11-2008 04:22 PM
Cheese Steak Nazi
10-17-2007 07:00 AM
sgribble
12-13-2002 12:41 PM
Quick Reply: Need help.....how to reset ECU
