Need help ! Got a Cell after K&N CAI on 06
I just finished installed my K&N Air Charger for MY 06. The 06 have a air temperature sensor on the intake elbow which I had to drill a hole in the K&N elbow to install the OEM sensor.
Took the car out for spin everything seem fine. Took the car out the second times the check engine light come on.
When to Autozone pull a code of PO 113 - IAT sensor(intake air sensor). They can't erased it. What can I do to fix this ? Thanks. for any help.
Originally Posted by RadioZero,Jul 4 2006, 04:17 PM
also what did you use the seal the IAT hole that you drilled? silicon sealant?
Originally Posted by Slows2k,Jul 4 2006, 02:04 PM
Did you unplug the IAT with the key on? Chances are that's the source of the DTC.
