Need Help With Exhaust Hangers Now!!!!!!!
I'M UNDER THE CAR AND I AM TRYING TO GET THE EXHAUST OFF. I GOT ALL THREE BOLTS ALREADY. AND USED PLENTY OF WD-40 ON THE RUBBER HANGERS..... HOW DO I GET TH EXHAUST OF THEM??? PLEASE HELP. THANK YOU......
QUICK UPDATE. I GOT THE HANGER OFF RIGHT BEHIND THE CAT. IT THE TWO REARS THAT ARE NOW GIVING ME THE PROBLEMS??CAN SOMEONE PLEASE HELP. THANKS
It took me a while to figure out how to remove the hangers too!
WD 40 or other lube should work fine. Make sure you have plenty of lube on both the hanger and the metal hanger supports on both the exhaust and frame. When removing the exhaust, remove the hanger from the support which has the least amount of bend in it. I can't recall right off hand if you will need to first remove the support from the exhaust or from the support on the frame. Good Luck!
Originally posted by airsport
Try grease instead of wd-40
Mine came off with little effort.
Veilside79
10-19-2007 12:42 AM
