NEED HELP engine sound
Old 06-16-2010, 07:50 PM
  #31
typewx's Avatar
just did a compression test. it won't hold long enough to get a reading. either the kit i borrow is broken or its time to buy a new motor.... =(
Old 06-17-2010, 05:55 AM
  #32
crank's Avatar
which cylinder(s)? and who built the motor? they did something wrong.....zero compression could mean a number of things.
Old 06-20-2010, 01:50 AM
  #33
Seattle2k's Avatar
you might be getting dtc p0108 because you have no intake connected.
Old 06-20-2010, 04:41 AM
  #34
TOGA's Avatar
Hi Typewx,
Ok from my experience this could be 2 things:
1. Valve clearance issue (You said before that you had the head resurface? if too much has been taken off valves will be touching)
What to do:
Do a compression test on all 4 cylinders if they read low its definitely bent the valves causing it to turn off on you cause there is not enough compression for the motor to keep running.
OR If someone has built or tamperd with the block a rod bolt might of not been torqued down properly this could be another possibility for the valve clearance issue.
2. Bottom end knock either a rod bearing or main bearing has given way. (most likely a rod bearing).
What to do:
Hook up an oil pressure gauge and see what it reads if it too low then its mostly likely bearing failure. you could also drain the oil dip your fingers in there and grind your fingers together to see if there are metal particles you can see or feel.
Hope this helps you and good luck.
Old 07-02-2010, 09:58 PM
  #35
typewx's Avatar
first of all I like to THANK all that have replied. I had a friend from skunk2 that came over to take a look at the motor. he said it's definitely coming from the bottom end. he told us to take out the tranny and see if everything is OK with the flywheel area. we did that today and found out the reason.[media]http://www.youtube.com/watch?v=rkyCUVk89Cw [/media]
Old 07-03-2010, 12:13 AM
  #36
jyeung528's Avatar
does that mean you get a refund on the bottom end that you bought?
Old 07-03-2010, 01:42 AM
  #37
typewx's Avatar
lucky for me, Mike from lasky racing is a cool guy. He will take the block back.
Old 07-03-2010, 04:37 AM
  #38
crank's Avatar
glad you finally figured it out !!
Old 07-03-2010, 01:10 PM
  #39
jyeung528's Avatar
i called it.
Fabulous_omelet
09-04-2015 12:02 PM
jdnissanz
07-22-2009 03:45 PM
roi
08-30-2007 05:37 PM
customcamry
08-05-2007 02:10 PM
pistonhead
02-28-2002 07:42 AM
Quick Reply: NEED HELP engine sound
