Need help diagnosing clunk in rear end
Old 12-07-2012, 02:33 PM
Kmelthratter's Avatar
The problem was me rushing reinstallation, the swap itself addresses the pitting issue which is independent of the clunk. The clunk is a known quirk with our cars, but if it gets excessive it would probably be a bad CV joint or bucket. Worst case scenario is leaving you on the side of the road and out $100 for a used OEM axle from ebay. My diff mounts went bad, and got worse before I fixed them, they caused the car to buck quite a bit, similar to a broken motor mount. The fluid came out of the back right (maybe back left as well) and the front right diff mount bushing had a large tear. 100% worth the money for new OEM mounts.
Old 12-07-2012, 08:38 PM
Brock227's Avatar
I replaced the diff bushes and the bucking was substantially less and the noise was still there, I'm quite convinced it may be the diff as it has the clunk and a gear type noise when on very light throttle at speed
leemaverickly
11-09-2015 03:11 PM
Honda_4life_
12-27-2013 07:17 AM
Brock227
02-11-2013 11:03 AM
DGlove2k
07-10-2012 06:02 PM
BARs2000
05-19-2006 03:07 PM
Quick Reply: Need help diagnosing clunk in rear end
