Need Help with Coolant Leak
Hey Guys,
I did a search before posting and didn't find what I was looking for.
I have an 01 S2000 with 65k on it. It's bone stock. Anyways, I was just out driving it and saw a little steam coming from under the hood. I pulled over and checked it out and there was coolant under the hood. On that foam part between the radiator and radiator support. Also it was on both the left and right sides of the radiator. The cap is on all the way and I can't find any other signs of a leak. Luckily the car never got above 3 bars on the temp gage.
Anything you can suggest for me to check would be greatly appreciated.
-s
-s
it could be many things. I first thought of a leaky cap but you said it was on both sides of the rad. Could be a pinhole in the rad core, or one of the hoses. You have to get the car fully warm and look around with a bright light.
I suggest purchasing an all aluminum radiator to prevent cracked plastic end tanks.
Hmmm im having a little leak too but my fluid drops down.below the oil filter. I know its rad coolant because only my rad coolant goes down. Dunno about any hoses down there but i dunno
Sorry for the grave dig lol. I searched google and this was the exact problem im having. Driving down the interstate and i see this liquid coming out of the side of the hood and it wasnt raining so i pull over and theres dried up radiator fluid residue all over the intake/hood/battery/engine bay in general and the little foam in front of the radiator was DRENCHED. It looked like it was sprayed but i couldnt figure out from where since it was everywhere. I immediately refilled the resorvioir and made sure it was at a correct level after the car was on. Today it did it again and when i looked there was a fresh splatter right over the radiator cap on the bottom of the hood. Its an 01 and the car only has 76k. It doesnt overheat or anything, but this is driving me crazy. I looked online and im just gonna replace it with an obx aliminum radiator off eGay for $200 unless anyone has any advice on the issue.
BTW this is my first post!
I'd suspect a cracked radiator like mentioned above as this is a common issue with the Honda plastic tanks , it could be a leaky cap but I would think that would be easy to see if that was the case.
If it is a leaky rad go with a Mishimoto aluminum rad, I just got one from GTMotoring.com, great rad for relatively low dough, almost 3 x the thickness of the oem rad, impressive piece and is a race proven rad unlike the OBX and isn't much more money than the OBX (which I usually associate with junk).
