Need help because of "VSA"
Old 02-28-2009, 01:08 AM
HH-S2000's Avatar
Default Need help because of "VSA"
Hey guys, i need some help......
I need every information about the VSA in the MY2006 model.
I need all the information keys, which where related together.
I mean from the dashboard sensor to every wires etc.
Because the f...ing company which build my car, removed a few thinks from my car, like wires and SRS unit etc
so my VSA dont works.
thanks a lot
Old 02-28-2009, 01:55 AM
MasterForce's Avatar
i think the only way to find something like this is in the factory service manual...dont know if theres a PDF version that someone can send you..
Old 02-28-2009, 02:37 AM
HH-S2000's Avatar
[EDITED]
[Sorry HH...that is copywrite protected material...don't use the site to engage in illegal activity. There are LEGAL copies available on eBay that you can purchase. Thanks. negcamber]
Old 02-28-2009, 05:19 AM
bgoetz's Avatar
If you had the steering wheel off I would start there. For what ever reason when that steering wheel is removed the VSA light seems to act up. I know there is a relearning process for the VSA steering angle sensor, I think the dealship may have to do it though.
Old 02-28-2009, 03:36 PM
HH-S2000's Avatar
ok sorry for my ilegal question.
But who can help me?? someone here, who had some good infos for me??
some pics??
where exact is this part located??
SENSOR ASSY., CLUSTER (YAW/LATERAL ACCELERATION) , SENSOR, CLUSTER
found this on this website
http://www.manchestermotorsports.com/index.cfm
MY2006 model, than electrical and than control unit cabin point 33
thanks
Old 02-28-2009, 07:23 PM
negcamber's Avatar
Seriously, this is what you need:
http://cgi.ebay.com/ebaymotors/Parts-Acces...%3A1|240%3A1318
There are not that many 06+ owners out there who have needed to do the kind of work you are doing. You may be blazing new territory. Good luck.
Old 03-01-2009, 04:31 AM
bgoetz's Avatar
That sensor is in the steering column. I had the same thing happen and had to take it to the dealer. They just put a new sensor in, although I really don't think they needed to, I just think they needed to make sure that the exhisting one was in the right posistion and then "relearn" it.
For your situation it would be helpful to know what exactly was done to your car (i.e. what was removed).
Old 03-02-2009, 03:01 AM
HH-S2000's Avatar
you mean the hubseonsor which is behind the steering wheel??
or you mean the sensor unit, which is somewhere behind the seats???
you have the 2006 model??
I dont know what happedn exact to my car :=((
The fu.... compnay called nnomo racing in germany, they build my car. the make a lot bullshit, and removed a lot of parts and dont give it back to me.
a lot of screws,they forgot to make it strong
so now i have to check out everything. my VSA dont work, because i think the removed the Sensor unit for the VSA.
Old 03-03-2009, 04:10 PM
bgoetz's Avatar
If they removed the sensor unit that is why your VSA does not work, it will never work without it. There are tons of different sensors for the VSA the one that is most commonly screwed up is the one in the steering column.
Old 03-03-2009, 05:09 PM
TheProfessor's Avatar
who needs vsc slip slip
Quick Reply: Need help because of "VSA"
