NEED HELP WITH BEARINGS
#32
the block can be honed again to get the cuts in it no need to re bore..but the material looks like bearing...but i see the block is apart..did you find out what the material came from yet???
#33
Originally Posted by xlaox,Feb 27 2008, 07:27 PM
whats 2stepping a launch? sorry im a noobie
With EMS, you can retard or add timing, add anti-lag etc... its very indepth!
#35
ohh ok, well then if the block has been worn down to its service limits then your going to have to get it re-bored..if you have a t-gauge and micrometer you can check each cylinder to make sure, or if not have the machine shop do that.
#39
ok, finally took the motor apart last night! It was a main bearing. The crank doesnt look scored though. Im going to clean it up tonight and have pics later.
#40
Ok, i checked the codes to get the colors for my main bearings to go into the block i got and it says i need 2 green and here is where I get confused, 2 yellow/green and 1 green/brown. Honda doesnt sell a color like that does it??? I thought it was always a solid color! So I looked up on Majestic and it doesnt list a yellow/green or a green/brown, just like i thought. Any help on what that means? Does it mean i need a yellow top and green bottom???
Any help would be greatly appreciated.
Thanks
Fadi
Thanks
Fadi
