NEED HELP WITH BEARINGS
Old 02-25-2008, 03:47 AM
NNY S2k's Avatar
Originally Posted by CourageOO7,Feb 25 2008, 01:33 AM
Oh my god that sounds awful. ...Sorry man, I think you're going to be needing a new bottom end.
Old 02-25-2008, 05:30 AM
jdmcrave's Avatar
Originally Posted by fadiss2k,Feb 25 2008, 01:44 AM
So, if it is my rod bearings, what all do i have to replace? Bearings,rods,crank?
First off make sure its that and dont go replacing parts..lol..that would suck if it turns out it wasnt it. But in the case it is a spun bearing chances are it score the crank and your going to have to have the crank re-shaved. So basically your looking at shaving off the crank rod journals and replacing all bearing with appropriate size bearings, but dont worry about that the machine shop will take care of everything and its not that expensive to re-shave a crank. Doesn't sound like alot of work but remember, that requires removing the engine and taking apart the block. Whats going to be a pita would be paying a mechanic labor for all that work. I guess thats why most people who spun bearings just replace the block all together, they can have the car running within one day.
Old 02-25-2008, 08:09 AM
fadiss2k's Avatar
I can pull the motor my self. I am going to hate doing it, but i can do it. Well, i guess ill go start pulling the oil pan off to check the bearings.
Old 02-25-2008, 08:14 AM
fadiss2k's Avatar
yeah, i was 2stepping when i launched. As soon as it was done jumping around and spinning the tires, all this happened.
Old 02-25-2008, 09:17 AM
street_ruler's Avatar
if it is a spun bearing you migh be able to save the crank and rod but dont bet on it.
Old 02-25-2008, 11:06 AM
jdmcrave's Avatar
wow...doesnt sounds healthy...yeh man..drop the oil pan and see what you can see...
Old 02-25-2008, 04:32 PM
AusS2000's Avatar
Will a spun bearing result in the oil light?
I guess if it is no longer seated correctly over the oil hole it could cause blockage or leakage.
Old 02-25-2008, 04:59 PM
fadiss2k's Avatar
That is the only thing i was wondering if it is a spun bearing.
Old 02-25-2008, 05:09 PM
jdmcrave's Avatar
thats a good question..I dont think it should but who knows?? Maybe the oil light is on as a precaution saying "HEY, SOMETHINGS NOT RIGHT!!!" and has something to do with oil..but then again thats what the check engine light is for..I dont know though..can anyone else chine on this??
Old 02-25-2008, 05:20 PM
nearwater4me's Avatar
That's painful to hear.
Did you pull the motor and see what's wrong?
Dan
Quick Reply: NEED HELP WITH BEARINGS
