Need Help!
Need Help!
Ok ill will make this short as I can. If I leave any info out please let me know, I was coming home last Friday night, as I was pulling away from a stop light i was going into 3rd and running about 3K rpms, and she just falls on her face.. I pull over cause I have no power but its still running, no lights or nothing, but had a rough idle.. While sitting there it seemed to fix its self.. So I make it home.. Next day I figured it was bad gas so I go up and put stablizer in the gas, seemed to be running ok, but then gettin on the expressway My maint req light stats flashing then goes out.. Now when I start the car Thae light flashes 10 times then goes out, so I took it to the shop and hook the comp and there are no codes, we tried clearing the codes, and it still flashes when i go to start the car.
So if you could give me some direction I would be greatful.. If you need any more info please let me know, Also to add to the story when i come to a stop now it acts like the car wants to stall out..
Trey
Trey
Maint req light is not the same as the CEL. You just passed over the mileage that maintenance is expected and you can turn it off (check out pg 51 of your owners manual).
Not sure what was going on with the rough idle or wanting to stall at a stop.
Klutch Master
04-07-2010 11:51 AM
ryan00davis
09-27-2008 09:46 PM
