Need help
was it working properly before taking it to the body shop?
I tried google search and YouTube and I can’t seem to find the help on how to adjust my driver side window height .
long story short got my car back from body shop but now my window doesn’t fully go up properly and doesn’t sit flush with the oem hardtop. the back of the glass slightly sags .The window still goes fully down just not fully up the rear seems to be stuck somewhere if I hold the button up and pull on the glass it comes up but then goes back down a bit .
You can see the gap where it’s missing to go up it gets stuck in the front of it I am assuming .is there anyway to fix this ?i don’t think it’s the motor because it still goes up and down
yea fully functional I took it to the body shop to get rock chips from the front end fix and It also had a long scratch on the door (no dent )
so they did a blend
I don’t know why would they remove glass ?
but also I am not a painter or know of how they work lol
so they did a blend
The window looks up on this photo lol but idk hahaha i am still hoping for loose screws .
a buddy of mine was saying is it possible that the regulator has gone bad.
can that be a possibility .?
When you pull the door card off you can see three holes in a kind of triangle shape where you can access the bolts holding the glass to the regulator. You'll have to lower the window to line up with those holes to loosen the bolts just a bit and then move the glass around and re-tighten.
and thank you guys for your time and help
I finally had time to do the work and thanks to you guys help
I found the window was loose from the 2 of the 3 screws holding the glass .causing it to have play and sag when I tighten them it was outta place still so I had to loosen up the 3 window stoppers like the manual photos cosmomiller added here and re loosen the glass crews all 3 of them .to be able to pull back and adjust window .I had my sons mother hold the glass in place while I went to tighten the glass screws again then tightened up the glass stopper that pushes up against the glass first then the other two after that I can now finally wash my car and do a full detail
thank you again fellas
Received 1,716 Likes
Glad it worked out. Sometimes having the right tools works! (Son's mother, LOL!)
GoP-Demon
06-10-2015 05:56 AM
