Need a good clutch fluid DIY
Anybody know where I can find a good DIY for replacing my clutch fluid. I've looked on the DIY sticky and done a search.
The link to xviper's no longer works. What happened to it?
Thanks a lot.
Thanks a lot.
There's on on s2kca.com.
It's quite simple though. Suck out all the old fliud for the resorvior. Fill it back up with new fluid. Remove the rubber nipple and put a hose on the barb. Using an 8mm box wrench crack the bleeder. Have someone press down on the clutch pedal. When the fluid stops coming out. Close the bleeder, lift the pedal up. Then crack the bleeder, psh down on the pedal, until new fluid comes out. Check and fill the clutch resorvior after a few pumps. Lastly on your last pump and fill pump the clutch pedal a few times. Dispose of the fluid correctly an you're done.
