Need DIY for Clutch Fluid
Does anyone know where I can find a link to decent DIY instructions for replacing clutch fluid? Either that or a good link to instruction manual to do the same. yea - I know it's not a hard job and I can figure it out myself, but I just want to make sure I do it right. Thanks for any help.
Jack the car up(use jack stands )locate the slave cylinder on the side of the transmission. Crack the line and drain the clutch fluid into a container and discard it. Put the line back on and refill the reservoir. Leave the top off and get a friend to pump the clutch until it gets pressure built back up. Get the m to then hold the clutch pedal to the floor while you crack the bleeder valve on the end of the slave cylinder. continue bleeding until all the air is out but dont let the reservoir run out of fluid
