Need Detailed Instructions on Installing Springs...
Old 08-30-2003, 02:41 AM
swtazn97's Avatar
i didn't have the ball joint remover. =*( but! They're two big bolts which sandwich that ball joint thinggie. If you remove it and swing the brake disc over and have someone step on the lower arm thing, you should be able to wiggle the whole damper out.
asura: which alignment settings should i use?
Old 08-30-2003, 12:27 PM
Asura's Avatar
[QUOTE]Originally posted by swtazn97
[B]i didn't have the ball joint remover. =*( but!
Old 08-30-2003, 02:27 PM
swtazn97's Avatar
i have the kg/mm race springs.
Old 08-30-2003, 02:32 PM
Asura's Avatar
What do you do with the car-what sort of driving do you do?
Old 08-30-2003, 02:50 PM
swtazn97's Avatar
it's just my normal daily driver. I would like to have the alignment settings the way it was stock.
guedo
08-10-2009 01:00 PM
sjsharks33
04-21-2006 08:06 PM
hansel
03-08-2005 06:21 PM
dp2580
11-12-2003 04:25 AM
S2K Mayhem
06-12-2003 08:41 PM
Quick Reply: Need Detailed Instructions on Installing Springs...
