need bolt sizes
need bolt sizes
i tried searching for the bolt sizes on websites that sell oem parts and stuff and i cant exactly find what size they are.
i need to know what bolt/ nut size bolts the catalytic converter to the header. also i saw a picture of a spring??? anyone can chime in i'd appreciate it on that.
and i need to know the size of the bell housing transmission bolts. (bolt the transmission to the engine case)
to hell with stealerships make a grocery list of all the bolts you need and go to lowes hardware. you might spend 15 bucks for everthing you need. after the 87th time i bolted my header back up i stopped using those spring bolts and just use regular nuts n bolts with lock washers. never had problems before i went with boost
