Need AEM EMS Help!
Need AEM EMS Help!
Need to figure out why my car won't crank over/start. It fires and sputters, but won't turn over the entire way. What values should I be checking? It was running last week. I have a half tank of gas. I checked the fuses and they are all fine.
Dan, are you sure you're holding the start button in long enough? With the EMS, the car will require a few more revolutions to crank up. You'll need to hold it down 2-3 seconds longer than usual. My tuner tells me that this is unavoidable.
This sucks because i need to drive this to get tuned with UL on Monday. So any help would be appreciated. BTW, stock ECU doesn't work with this car, because of the ITBs. I tried already.
u change your injectors? is it cold up there???? maybe there is something wrong with ur cold start....
was the temp different from when you first started the car last week and yesturday??/
Beroz
Beroz
Sean? No I bought it used from Art (topfuel) with his maps for the ITBs. I've tried using them and they didn't work, I was able to use the stock maps from AEM Forums. But now they don't seem to be working either.
