Need advice: Going to buy a used motor
any advice to inspect a motor that is not connected to a car.
im thinking a compression test and a leak down test? both can be done being out of the car? anything else? thanks
ive seen it done before at least ive seen the compression test done on a motor that was already pulled out of a vehicle. What i think you need is a functional battery and perhaps a starter or something of that sort.
Leak down is easy out of the car. I would also pull the rocker cover to check the retainers, and if all looks good, as a last step cut open the oil filter with the correct tool to see if the engine is making metal.
Originally Posted by chef-j,Jul 9 2010, 04:30 AM
Compression test, you need to crank the motor, idk if you can do without flywheel in. But leak down test can be done.
payyourtoll
03-19-2004 10:54 AM
