Name that bolt
Old 03-21-2016, 05:25 AM
captb's Avatar
Default Name that bolt
Hi S family. I need a bit of assistance.Recently driving in a parking lot at about 5mph I hear a clunking noise asif something fell off the car.When I went to check I saw this bolt on the ground but can't figure out what is it for.
Somerecent work on the car was replace the rear knuckle,removed one of the axles,clutch master cylinder and slave, routine maintenance like diff fluid, oil, trans fluid.
The bolt seems to be a hex 6mm. Any ideas what it could be?
Thanks
Old 03-21-2016, 06:08 AM
chefs2000's Avatar
Looks like axel bolt
Old 03-21-2016, 06:20 AM
305AP1's Avatar
either its an axle bolt or a drive shaft bolt .
Old 03-21-2016, 06:56 AM
chubbys2k's Avatar
Driveshaft bolt.
Old 03-21-2016, 06:58 AM
baZurk's Avatar
looks too small to be a driveshaft bolt, but go ahead and check anyway, then check all the bolts on your oil pan, it's possible someone used this allen bolt as a replacement for a broken oem bolt.
Old 03-21-2016, 07:09 AM
cdelena's Avatar
propshaft.
Old 03-21-2016, 07:35 AM
windhund116's Avatar
Received 1,530 Likes on 1,034 Posts
That bolt is too small for prop shaft, which are 10mm diameter (prolly 14mm wrench size).
http://www.hondaautomotiveparts.com/...ROPELLER+SHAFT
Old 03-21-2016, 07:52 AM
Bullwings's Avatar
looks like "C" in the picture below
Old 03-21-2016, 08:15 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
Front (transmission flange) driveshaft/propshaft bolt, AP1, 100%.
AP2 are 10mm bolt size.
The others are likely loose also.
Clutch recently?
Old 03-21-2016, 09:30 AM
captb's Avatar
Thanks everyone, I'll check all of these. I don't however remember using an allen wrench on the axles. and I did have my clutch replaced about a year ago (not by me). I'm guessing I should probably avoid driving it until this is fixed huh.
Quick Reply: Name that bolt
