Mystery problem with car..
Originally Posted by SCCS2K,Jul 30 2008, 10:20 PM
have you done compression/leak?
my off-the-wall guess would be...hmm...coilpacks maybe? you've actually got much of the obvious stuff covered.
Originally Posted by Slows2k,Jul 30 2008, 10:17 PM
Non existent.. The BARO sensor is built into the PCM. Can't check it's votage without a high dollar scan tool.
Have you checked fuel pressure?
MAP and BARO volts should be within .02V of each other, usually they will be around 2.5V, depending on your altitude above sea level. If you have MAP at 2.4V and BARO at 2.5, try another MAP sensor.
Originally Posted by Togobox,Jul 31 2008, 10:24 PM
did you replace the o2 sensor with OEM sensor?
