MY2000 with original spark plugs.... worth doing?
I would check them and re-torque them to the proper spec but not sure I'd spend the $$ just because of age.
Take a look at them and then decide if they need replacing:
Once all four of the old plugs are out, check them out - this is a great time to get an idea of how your engine is running.
Here's the general rundown on plugs:
White - lean and hot
Light brown - perfect
Dark brown - rich
Black - oil fouled or very rich (wet black is oil, dry black is carbon)
S2000s generally run white to light brown. If you see dark brown, I wouldn't worry, but you shouldn't see black unless you were having problems before you checked the plugs. Also, with our engines, cylinders 3 and 4 (the back two) are more likely to look fouled due to blow by through the PCV, fyi.
from: https://www.s2ki.com/s2000/topic/765...ug-change-diy/
Dark brown - rich
It's a 30 min job.If you take the time to pull & check,go ahead & replace.
I run NGK BKR7E($2 ea) ,Gap .040 on my 03 w/99k miles.Plugs are light tan every time.
\rlr
carolina
\rlr
carolina
Just outta curiousity how does 24ft pounds feel on a normal sized socket wrench? (i know ill buy a torque wrench) but i already changed them and im wondering if in f*cked. runs like a dream for about 7k miles since the change
