MY06 Valve cover won't come off.
#22
I got the snapped bolt to come out today and while checking the other valve cover gaskets/bolts, I noticed a small amount of oil perspiration around the 5 rubber valve cover gaskets. It looks like a small amount came out and stopped as the gaskets became more seated to the cover. Should I be worry and retighten the valve cover gasket/bolts?
#24
if you use a small 1/4 inch drive ratchet and 10mm socket just make sure they are hand-tight and snug, you shouldn't over-torque them with a small sized ratchet, and you shouldn't see any oil seeping out of new gaskets.
#25
Originally Posted by MegaTRon' timestamp='1358997411' post='22288201
I forgot to mention that these are brand new gaskets/washers.
