MY04-05-06 clutch delay slave cylinder removal
#32
Originally Posted by 03exlcoupe,Apr 11 2005, 05:56 PM
my brother picked up that suggested napa hook kit and the clip finally came off! what are the torque specs on the hydraulic bolt (not the bleed valve)?
tks
tks
Not sure on that one.
I wouldn't go over 35lbs though. Most of the torque specs for plugs and bolts are 33-35 lbs.
So are you STILL doing this mod? or are you enjoying your new car yet?
#33
tks
tks
The 2 bolts that secure the slave cylinder are 16 ft.lbs.
#34
just got back from my drive with my new car! thanks for all the help, fellow moders. the engagement is closer to the floor and the pedal feel is much more consistent. I ran it to redline a few times and it felt great.
#35
#37
Originally Posted by spotch,Apr 11 2005, 08:11 PM
anyone have a rough estimate for the price of an 03 slave cylinder?
#38
Excellent write up
I replaced the cylinder with an 03 model in my last S, but decided to modify the existing cylinder in my 05. The snap ring is a pita, but it finally came out. I figure this way, if my dealer has to check underneath for a warranty issue, everything still appears to be stock.
#39
Originally Posted by Cyclon36,Apr 12 2005, 06:25 AM
Excellent write up
#40
Originally Posted by spotch,Apr 12 2005, 01:58 PM
Do the 03 and 04/05 slave cylinders look noticeably different?
