MY04-05-06 clutch delay slave cylinder removal
Old 08-14-2005, 03:36 AM
  #121
kumar75150's Avatar
To people that are having trouble with the snap ring: an alternative is to drill a small hole on the side onf the cynlider right under the snap ring so you have an access point.
That way you can take the pick and push up on the snap ring from underneath and it comes out right away.
Old 08-14-2005, 10:32 AM
  #122
SIIK2NR's Avatar
Originally Posted by johnqt3,Aug 13 2005, 04:28 PM
well i stopped the clutch bleeder from bleeding and its full my now my car wont turn over... ahhh why is this happening. i did the bleeding correctly and a more then a few times making sure the resevoir was full at all times. my clutch seems loose at first too when i pump it but after pumping it a couple times it stiff where it should be... but i think when i let it rest a little and pump some more its light at first again and will get stiff after a couple pumps. can someone hep please... i need to get the car running again.
Please read the write up on bleeding the clutch.. You have to do it EXACTLY like it says to ensure you have all the air out of the lines. You need 2 people to do this properly unless you have a vacuum pump.
If your clutch is not properly pressurized then your car will not turn over. It's like trying to start the car without your foot on the clutch......nothing.
Bleed it properly and it should start fine....
Old 08-15-2005, 07:50 PM
  #123
terahertz's Avatar
i finally did it today =] feels great except the pedal doesnt feel as firm as it used to be. is that how it should feel? i do know that the do nothing zone of the pedal is larger meaning the pedal is lower.
Old 09-11-2005, 03:01 PM
  #124
redlineF22c1's Avatar
Removed mine yesterday with the help of my friend(ASE certified master mechanic), took him like 15min to get it out and back on. He used some hooked screw drivers to get the snap ring out. (took him a few min, so don't feel bad). Then to get the delay valve out he covered one end with a rag and stuck a 150psi hose with rubber tip to make a seal and blasted it out. Put everything back together and on the car in 15 min. Then we bled the clutch, took it off the lift and no more crappy shifts.
Old 09-11-2005, 03:29 PM
  #125
Picturepro's Avatar
I did my mod a month ago... its all good now...
I dont know why some people would question it.... why do it?
Old 11-28-2005, 07:08 PM
  #126
2QYK4U's Avatar
Should I (can I) do this mod to my '06 S knowing that is has VSA and DBW? Not sure if those two upgrades change the scenario any.
Old 11-28-2005, 07:13 PM
  #127
SIIK2NR's Avatar
Yes you can .....
Neither the VSA or DBW have anything to do with the Slave cylinder.
Old 11-28-2005, 07:14 PM
  #128
2QYK4U's Avatar
Originally Posted by SIIK2NR,Nov 28 2005, 09:13 PM
Yes you can .....
Cool.
BTW...I live in San Diego as well. Do you think you could help me with this mod? I'd pay you for your time.
Old 11-28-2005, 07:18 PM
  #129
SIIK2NR's Avatar
Originally Posted by '05 S2K SBM,Nov 28 2005, 08:14 PM
Cool.
Wtf??? You live in San Diego and you never holla!!!??? come out to the meets mang..
Yeah I'll help you with it... I've done probably 20 of these already...
Make sure you get all the parts/tools and PM me when your ready.
Takes about an hour or so...
Tim
Old 11-28-2005, 07:19 PM
  #130
2QYK4U's Avatar
Tim
I've lived in San Diego for about 10 years now...but I have only had my S for about 2 weeks now.
I have all the tools but the dental pick...
Quick Reply: MY04-05-06 clutch delay slave cylinder removal
